d15z1 in d15b6 motor
Old 10-01-2009, 06:13 PM
ta_paparia_mou's Avatar
ta_paparia_mou has disabled reputation
Default d15z1 in d15b6 motor
so im pretty new to the swapping and rebuild scene and i have a couple questions.sorry if they are stupid ones. 1) can i just straight up swap out my pistons in my d15b6 motor for d15z1 pistons without doing anything else?from what i have researched they have the same bore and stroke. just a higher compression, which im trying to do so i can get more hp. 2)if i run higher compression,what do i have to do to make sure everything is in working order so i dont blow the motor .any help would be great.Thanks!
ta_paparia_mou is offline
Old 10-01-2009, 06:25 PM
Digital Life
83Stang5.0's Avatar
Default Re: d15z1 in d15b6 motor
I don't know how much compression you'd gain from Z1 pistons, but I doubt it's enough to really matter.
If you want higher compression, get D16A1 pistons. You'll be at atleast 12.0:1.
Once you're at that high of a compression ratio, you need to get your ECU chipped and tuned specifically for the setup before you ever start the motor.
83Stang5.0 is offline
cardinalredeg
Engine / Exhaust / Drivetrain
06-24-2009 03:41 PM
nastyz28
06-11-2009 07:16 AM
efhatchlover
08-16-2007 06:39 AM
92hatch
10-17-2003 11:15 AM
Quick Reply: d15z1 in d15b6 motor
