d15 problems
ratty
d15 problems
early today my car wouldnt even start do to the fact that i had forgot to tighten the thermostat ground i tightend that up and it fired up but reved to about 3000 rpm and wouldnt go down, so i looked at the spark plug wires and they where mixed up i put em on right then started the car now it stil runs like shit but it idles up and down the rpms go crazy im not to sure what to look for now? any imput or help would be awesome
TurboPipingSystems
Re: d15 problems
Any CEL code? What reference did u use to reinstall the spark plug cables? I hope not Haynes.... Also, look around the area where the thermostat ground wire is. There are a few things in that area that can cause an idle to do that. Check things like IACV connector, Map Sensor, vacuum lines, and TPS.
ratty
Re: d15 problems
ratty
Re: d15 problems
well i never took it out i changed the clutch a while ago and i guess i just missed the ground i didnt see it cause the harness runs right over top of it but thanks for the diagram
b00stedGsR
Want to Buy / Trade ARCHIVE
12-11-2007 09:28 AM
