crx window problems
crx window problems
i have a crx that i put a new window in now when i roll the window up it comes up sideways??i put it in the same way it came out,any advice??
Re: crx window problems
if i recall correcty dont crx door glass's have a tab that holds them in a track in the rear of the door? did you replace/install that? if you did you may need to put the glass halfway up and then push it sideways so that the tab snaps into the track...
is the right year match 88 and 89 are th same , 90 and 91are the same(i think that's right) if it the wrong year it won't bolt to the bottom right i made that mistake once
its probably the wheel on the regulator track that broke off, mine did it to. Every time you roll down and back up it comes off track. Right? 89-91 uses same regulator. Have to replace whole regulator. Can't buy just the wheel. If you have a little mechanical knowledge you can make the 88 regulator work by relocating two holes. Good Luck! 88 is all by itself otherwise.
