crx problems
crx problems still doing it
ok well i did everything yall said and still acting up ..
when the car is sitting still and you hold the gas down just a little bit it rev up and down .. when you drive it when you barely hold the gas down it jerks and bucks . but when you get on it it works fine ..... checked the ecu and its throwing a code 14aand20 but its not throwing them with a long flash and four short blinks its blinking 14 shorts blinks i changed the ecu and the same problem ??? i also change the ivac still throwing that code and the 20 what is the 20 all about ??/
thanks jake
thanks jake
Last edited by crxgsr2004; 05-16-2006 at 12:51 PM. Reason: did everything tat yall said
Re: crx problems
So what exactly is your problem? Glass, bucking or what? If you have an Metal Intake, Chance's are it is grounding out on the battery, causing your car to buck. Has happened to me several times. Try putting insul wraping around it, or atleast a rag.
Re: crx problems
Originally Posted by crxgsr2004
the bucking i dont have a intake but i did just relocate my bat ?/
Sounds like you have a loose ground somewhere bro.
Ghost
Re: crx problems
A general rule of thumb for troubleshooting is that if a problem appears after making a change in something, that problem is directly related to the change.
So I'd find "the guy" and ask what exactly he adjusted, and go from there.
Re: crx problems
well i adjusted it and same thing is it true that if my battery was grounding out it would do this because i just relocated it in the rear ..
thanks.. the glass has nothing to do with the problem im just upset im have issues with it runnig it was broke into and i just got the glass replace and i want to go out and i had problems so sorry if i sounded like a retard..
