crx ignition problems
Old 02-11-2013, 12:11 AM
jdm89krix's Avatar
jdm89krix has disabled reputation
Default crx ignition problems
ok people, i have a 89 crx hf with the b2 dualpoint, and i cant get it to start. iv check all fuses and relays, the starter is good the battery is good. so iv come to the conclusion that the problem must lie with the ignition somewhere. any help or suggestions would be greatly appreciated. thanks.
jdm89krix is offline
Old 02-11-2013, 05:27 AM
TAINT PUNCHER!
Slooby's Avatar
Default Re: crx ignition problems
I assume its a manual, unhook the clutch safety switch and use a piece of wire and jump the plug. If it still doesn't start, it is most likely your ignition switch, there are one of two ways you can fix it, either wire in a electric start or replace the ignition switch.
Slooby is offline
fmstatic
04-12-2005 08:35 PM
BlackSRT4
03-31-2005 04:44 AM
sikkcrx
01-19-2004 12:55 PM
Cpt. Non-Spell
01-13-2004 08:07 AM
CRXtacy
05-12-2003 04:45 PM
Quick Reply: crx ignition problems
