crap need help
Old 05-27-2006, 07:22 PM
hungry
Rueben's Avatar
Rueben Rueben Rueben Rueben Rueben Rueben Rueben Rueben Rueben Rueben Rueben
Default crap need help
my 96 240sx for some reason, none of the front panels, dash, gauges, power windows and locks and brake lights work. the car still runs but if u want all that to work you have to drive around a bit, then it randomly turns back on. i noticed that after everything does turn on, every time i shift gears the lights and radio flicker. i checked all the fuses and none of them are busted. any ideas would really help
Rueben is offline
Old 05-27-2006, 09:13 PM
Ross's Avatar
Ross is an unknown quantity at this point
Default Re: crap need help
I would recomend checking your grounds first. There is most likley a common ground on all of those circuts. Check the FSM for ground locations, and ground circuts.
Ross is offline
Old 05-27-2006, 09:24 PM
miss my 2 wheels
brokemyR1's Avatar
brokemyR1 is an unknown quantity at this point
yea had a similar problem in my del sol...the radio installed didnt have the dimmer wire(for when you turn on your lights) attached...and would blow a fuse and cause my cluster/radio/brake lights to cut off...found this out and taped it up so it didnt ground out and everything was fine from then on...
brokemyR1 is offline
Lowfuel
02-20-2009 10:21 AM
Quick Reply: crap need help
