compression stuck in cylinder
went to do a compression check....lubed it up before i put it down there...went to take it out and the hose popped off....now the part that tightens in the cylinder is stuck....anyway to get this out????
Brown Water
Re: compression stuck in cylinder
I just had a buddy that had this happen to him with his h22. Just get an extraction tool, which is like a reverse cut drill bit and remove it. Your local parts store should carry it. But you may not be able to save the compression fitting since the exraction tool does damage the piece being removed.
if its still stuck go to your auto parts store or find a snap on guy and ask for a twist sockets, guaranteed to work im a mechanic and its saved my ass plenty of times
watisjdm
Want to Buy / Trade ARCHIVE
12-10-2008 05:25 AM
Fl1pSde 101
01-29-2008 06:56 PM
