Color Wire of ECU Throttle Signal
Old 11-20-2003, 01:30 PM
Wii
Retired OG
Wii's Avatar
Wii Wii Wii Wii Wii Wii Wii Wii Wii Wii Wii
Default Color Wire of ECU Throttle Signal
For a 99 D16 Civic, on the ECU, what color is the throttle signal wire?
Wii is offline
Old 11-20-2003, 06:57 PM
The TPS wire is D1, which is the first pin on the 16 pin connector. if you are looking at the ecu end with the plugs going into it, it's the connector all the way to the right (the small one) and the pin in the upper lefthand corner. I believe it may be red, but I don't know. I know the location, but not the color...
Old 11-21-2003, 05:24 AM
corona connessuer
CHAHONDA's Avatar
at the tps it is a red wire. at the ecu i cant remember
CHAHONDA is offline
Old 11-21-2003, 06:14 AM
Wii
Retired OG
Wii's Avatar
Found it. Its the Red with gren stripe
Wii is offline
LXative
02-26-2005 10:12 AM
Quick Reply: Color Wire of ECU Throttle Signal
