-   -   code 14???? (https://www.vadriven.com/forums/tech-talk-9/code-14-a-141709/)
MrZoggs May 31, 2006 11:10 AM
code 14????
i just did a GSR swap on my civic and since then ive been throwing a code 14( IAC (EACV) - idle air control valve)...anyone know anything to try?
lookattheAC May 31, 2006 11:12 AM
Re: code 14????
i dont really have much knowlege about the code but i know that IAC valves go bad on GSR's alot, try replacing it or cleaning it?
sk8rmike Jun 1, 2006 04:39 AM
Re: code 14????
pull it off and clean the small screen inside with some brake parts cleaner if it looks dirty. sometimes they get clogged up. also check to make sure you didn't fuck up the plug or wires going into it when you dropped the motor in, as that is very common too.
