clutch problems
Old 01-27-2010, 01:25 PM
KPVal757's Avatar
KPVal757 has disabled reputation
Default clutch problems
I am having clutch problems and i need help, hence this post...one day i was driving and i notice that my pressure point on my clutch pedal has change it was in the middle, now its all the way down by the floor....could this mean my clutch is about to go, or do i have to adjust my clutch cable?
side notes.
2000 acura integra ls
kinda high rpms around 1200 at idle
any help would be useful..thanks
KPVal757 is offline
Old 01-27-2010, 02:17 PM
Works on S2000's.
C Ory's Avatar
C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory C Ory
Default Re: clutch problems
Clutch slave cylinder or clutch master cylinder.
You don't have a clutch cable, it's all hydraulic. Check the fluid, top it off, bleed it, and see if you can see which one is leaking. Look up under the dash, and look at the clutch pedal and see if there is brake fluid leaking inside, if so, it's the master cylinder.
C Ory is offline
Old 01-27-2010, 02:58 PM
KPVal757's Avatar
thanks man gonna check that out asap!
KPVal757 is offline
Old 01-28-2010, 03:46 PM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
+1.
backtoarms is offline
H22accord jdm
12-25-2009 06:53 PM
awd4lyfe
09-24-2007 09:46 AM
USElesRyDeR01
06-13-2006 09:55 PM
SubZero240sx
02-09-2005 07:18 PM
sikkcrx
03-22-2004 03:24 PM
Quick Reply: clutch problems
