civic wont start (no fuel)
Old 02-08-2005, 05:35 PM
llatidamn's Avatar
llatidamn has disabled reputation
Default civic wont start (no fuel)
Car: 95 civic w/ built gsr swap less than 5k on motor
Problem: Car wanted to overheat while sitting in traffic. Checked fan and it was on, and with less than 5000 miles im sure the water pump is still good. Changed thermostat and filled and burped system. Car ran fine sitting in driveway for 20 minutes or so with no overheating. I later went out to the car to start it and it starts and immediately dies. I give it gas and it starts again and stays running while i nurse the gas pedal. When I let off the gas it dies again. I try to start it again and it will not start. When turning key to ignition position the main relay clicks constantly and the check engine light is dimly lit and flickering to the sound of the main relay and the fuel pump will not cut on. I tested the main relay and it works fine outside the car. The light on the hondata is on as well but blinks slowly. I also checked all plugs and connectors underhood and all appear good. Anyone have any ideas what could be wrong?
llatidamn is offline
Old 02-10-2005, 02:06 PM
swtch7's Avatar
swtch7 is an unknown quantity at this point
Default Re: civic wont start (no fuel)
http://www.honda-tech.com/zerothread?id=1145193
swtch7 is offline
Old 02-10-2005, 02:54 PM
1slowCRX's Avatar
1slowCRX is an unknown quantity at this point
Sounds like it could be the ground on the thermostat
1slowCRX is offline
Old 02-10-2005, 04:09 PM
llatidamn's Avatar
I checked that. Its good and tight and theres no corrossion. The fuel pump and injectors are not getting power. The main relay is clicking when it is in the car but outside of the car it tests fine. I had an ecu go bad before that caused the same problem so I swapped ecus and its still a no go. Thanks for the response though.
Old 02-19-2005, 06:50 PM
llatidamn's Avatar
well i know i said i checked it and that there was no corrossion and it was good and tight but that was what the problem was. i ended up running a ground from where the thermostat was directly to the battery and it started fine.
Old 10-20-2009, 11:36 AM
ericbrox's Avatar
ericbrox has disabled reputation
you over heated it do a leak down test
ericbrox is offline
Old 10-20-2009, 11:40 AM
jdm jim's Avatar
jdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these partsjdm jim is infamous around these parts
it soundslike a power supply issue.check all the connections
jdm jim is offline
Old 10-22-2009, 08:30 AM
backtoarms's Avatar
backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms backtoarms
If you over heated it, might be a head gasket or warped head. Honda's (or anything with an aluminum head) are bad about that. Do a block test.
backtoarms is offline
Old 10-22-2009, 09:28 AM
This is a four year old thread. Check the date before posting.
2kCivic_GSR
10-21-2009 10:58 PM
ek-bendy757
07-29-2008 09:43 PM
pimpingreen13
12-29-2007 08:17 PM
REDHONDA
08-08-2006 12:20 PM
200+hp240sx
04-26-2005 05:32 PM
Quick Reply: civic wont start (no fuel)
