Civic Fuel Pump Issues
Old 11-18-2006, 09:44 AM
"SI"ngle Cam's Avatar
"SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam "SI"ngle Cam
Default Civic Fuel Pump Issues
I'm having an issue and it's a little weird. When I turn my car on, the fuel pump isn't coming on for a good 10 seconds or so after I turn the key. Anyone have any ideas as to what would cause that to happen? I'm at a loss.
"SI"ngle Cam is offline
Old 11-18-2006, 10:30 AM
93VAHatch's Avatar
93VAHatch has disabled reputation
Default Re: Civic Fuel Pump Issues
The main relay on mine went out, it is located underneath the drivers side panel kind of behind the fuse box on most civics.
When you turn the key, it turns on the fuel pump to pretty much prime the fuel system. Mine did not fail immediately it worked some times and other times did not. Got one at a junk yard. Let me know if that sounds like your problem?
93VAHatch is offline
Old 11-18-2006, 10:40 AM
If it was the relay it wouldn;t be coming on at all I believe. It's coming on....just delayed....Relay was my first thought though. Any other ideas before I take my lazy ass to get one?
Old 11-18-2006, 12:17 PM
MaxPower's Avatar
Test to see if there is voltage going into and coming out of the relay when you turn the you key before you go and buy another one.
MaxPower is offline
thule
10-12-2005 09:52 PM
leolo007
09-12-2004 07:44 PM
Quick Reply: Civic Fuel Pump Issues
