check engine lights comes on after rear disc install
I Heart My Coupe
i have a 94 coupe dx no abs..and the rear disc i got is from i believe a 96 integra with abs..
so after doing the install i started up my car and my check engine light comes on.
ive resetted the battery and even taken the ecu fuse out for 30 seconds even. and the CEL is still on.
what can it be?
help
what can it be?
help
Re: check engine lights comes on after rear disc install
scan it and find out. i dont see why it would have anything to do with your install. if you dont know someone with a scanner, advanced will do it for free
I Heart My Coupe
I Heart My Coupe
so i did what wright told me to do..and im throwing a code 7 which is my TPS sensor...hmm..i wonder why it shitted out on me while do a rear disc install..
so i need a TPS thank you for the help
I don't think it has anything to do with the brake install, I think it's purely coincidence. If you have non-ABS brakes, and didn't touch any electrical wires, you couldn't have damaged anything electrical. If you damaged a 5V-powered wheel speed sensor or something like that, then you could have damaged the ECU. (which is supplying the 5V power). That would be the only possible explanation, and that's REALLY stretching the bounds of reality.
TYPE JDM
11-29-2009 11:42 AM
90lscrx
12-17-2008 12:33 PM
