check engine light 94 eg d16y8
Old 04-10-2009, 04:46 AM
jts_eg's Avatar
jts_eg has disabled reputation
Default check engine light 94 eg d16y8
car is sputtering badly until it warms up, afterwards seems to run fine, throwing a check engine light but with motor on or off with the key turned there is no light on the ecu flashing, it just got new NGK plugs and wires, any ideas?
jts_eg is offline
Old 04-10-2009, 07:59 AM
jts_eg's Avatar
Default Re: check engine light 94 eg d16y8
its throwing a 09 code cylinder 1 pos sensor, anyone know where this is located?
jts_eg is offline
Old 04-10-2009, 10:51 AM
It's in the distributor. Try a different distributor and if that doesn't fix it, it's probably a wiring problem.
D1NONLYJV43
06-01-2008 06:55 AM
91tegrsjg
11-14-2007 09:27 AM
famlyride
10-18-2007 05:26 PM
93DelSlo
09-24-2007 06:28 PM
marshallbc
11-15-2005 05:48 PM
Quick Reply: check engine light 94 eg d16y8
