CEL P0455 1998 Audi A4 Quattro Help
CEL P0455 1998 Audi A4 Quattro Evap System Help
Hi,
Just wondering if anyone has any clue as to the problem with Cel P0455 on an 98 Audi A4. Here is the diagnostic report from a code reader:
P0455
Evap Emission sys leak detected (gross leak / no flow)
misfire ok
fuel sys ok
comp component ok
cat mon inc
htd catalyst n/a
evap syst mon ok
sec air system n/a
a/c refrig mon n/a
oxygen sens mon inc
oxygen sens htr
egr system mon n/a
I also smell gasoline inside the cabin (definitely different from exhaust gasses). Also, when I get near empty and gas light comes on, after a car restart, gas level goes back to a little over empty and gas light turns off (a definite move in the needle, not just parking on inclines, etc.). Happened about twice before I decided to refuel.
I have checked as many vacuum hoses and had a roaming mechanic do the same and no hoses from the EVAP system were found to be leaking.
Any ideas? I dont feel like spending over a 100 bucks just to diagnose this at the dealership.
Thanks!
P0455
misfire ok
fuel sys ok
comp component ok
cat mon inc
htd catalyst n/a
evap syst mon ok
sec air system n/a
a/c refrig mon n/a
oxygen sens mon inc
oxygen sens htr
egr system mon n/a
Thanks!
Re: CEL P0455 1998 Audi A4 Quattro Help
If you smell gas in the car take it to the dealership. It's better than throwing parts at it and trying to fix it and you'll spend less in the long run.
crx4life
Import - EUROPE
06-08-2010 06:31 AM
