Car wont stay running - Any Ideas???
Old 06-04-2011, 05:41 PM
89 Si Hatch
Gadianton Racer's Avatar
Gadianton Racer has disabled reputation
Default Car wont stay running - Any Ideas???
Just thought Id see if anyone here could help me. I just got a 91 Honda civic and I cant get it to run. Well I sorta can, but let me explain. So when you turn the key forward the car turns over and starts. But as soon as you release the key and it goes back to the "on" position I guess, instead of the "start" position, the car cuts off. Any ideas would be helpful. And yes I know I could just take it to a shop so please dont tell me that. Just trying to see if anyone has had this happen or knows of a simple part I could change to fix it. Thanks in advance.
Gadianton Racer is offline
Old 06-04-2011, 08:23 PM
ItIsWhatItIs
LoveMyLS's Avatar
LoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond repute
Default Re: Car wont stay running - Any Ideas???
if the dash lights are also cutting off after you release the key, then it is more than likely the ignition switch failing.
LoveMyLS is offline
Old 06-04-2011, 09:43 PM
husoo's Avatar
husoo has disabled reputation
my car did someting like that we jst clean the battery the things hooked around the batterr idk what you call them but they were coroted just try creaing that and it should work it did for me sorry it dont work
husoo is offline
Old 06-05-2011, 04:21 AM
onesick97ek's Avatar
onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek onesick97ek
Terminals is what they are called
onesick97ek is offline
Old 06-05-2011, 05:10 AM
Go cry to momma
Nunyabidness's Avatar
Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness Nunyabidness
to whoever taught you how to put letters next to each other and call them 'words'
Nunyabidness is offline
Old 06-05-2011, 09:40 AM
Grab a multimeter and see what's happening with the power coming from the ignition switch. It sounds like the switch is going bad though.
Old 06-06-2011, 02:53 PM
89 Si Hatch
THanks fellas! It was indeed the ignition switch.
tenacious
05-28-2011 07:08 AM
sshhbequiet
07-01-2009 12:04 PM
streetsk8er757
01-12-2005 10:00 PM
Quick Reply: Car wont stay running - Any Ideas???
