car wont start...please help
Old 12-26-2007, 05:23 PM
94_CRVtec's Avatar
94_CRVtec has disabled reputation
Default car wont start...please help
so i went out to my car the other day and it wouldnt start, come to find out the starter went out...no biggie i change the starter out with a new one and now it cranks just fine and all but it still wont start. i noticed some very strange things, first when i am cranking the car the speedo jumps then slowly goes down after i stop cranking, and second the main relay makes an odd sound after i try to crank the car almost like it gets stuck. i have already tried replacing the main relay with 2 others with no luck, i have checked all other fuses and relays that i can thank of to check with no luck, if anyone else has any other advice that would be great.
94_CRVtec is offline
Old 12-26-2007, 05:30 PM
team703's Avatar
Default Re: car wont start...please help
your timing belt broke? you getting a spark?
team703 is offline
Old 12-26-2007, 06:01 PM
94_CRVtec's Avatar
Timing belt is fine. Haven't checked the spark yet.. my main concern is the strange sound coming from the relay.
Old 12-27-2007, 12:38 AM
Means Slow
MABAGAL's Avatar
MABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud ofMABAGAL has much to be proud of
check your grounds.
MABAGAL is offline
Old 12-27-2007, 12:30 PM
QUICKVIII's Avatar
QUICKVIII has disabled reputation
Originally Posted by 02_Blazin
check your grounds.
It's the first thing I would do also.
QUICKVIII is offline
Old 12-27-2007, 04:59 PM
Full Access Member
jlgrtype's Avatar
jlgrtype jlgrtype jlgrtype jlgrtype jlgrtype jlgrtype jlgrtype
a low battery could also be the problem. jump it to make sure.
jlgrtype is offline
Old 12-31-2007, 03:08 AM
ALL ABOUT THE TORQUE
ricedoutaccord's Avatar
ricedoutaccord has disabled reputation
it has a new cap, rotor, plugs , wires i took the cap off and checked it and there is like a white residue on the contacts. i also noticed one of the screw holes were cracked. so im guessing that its geting moisture in it. im going to replace it today.
ricedoutaccord is offline
Old 12-31-2007, 03:20 AM
Pew pew pew pew
02GT's Avatar
02GT has disabled reputation
Symptoms of a dead battery or you have a bad ground
02GT is offline
Old 01-01-2008, 08:51 PM
wierdguy75's Avatar
wierdguy75 has disabled reputation
Make sure your Spark plugs are firing, you can do this by taking one out and having someone crank the engine while you hold the spark plug and see if it sparks.
wierdguy75 is offline
gen4H22A
11-23-2008 05:22 PM
TYLERp
09-03-2008 10:52 AM
sive ick
12-22-2006 02:42 PM
jstabb1
09-12-2006 05:46 PM
HateV8s
02-21-2005 05:05 PM
Quick Reply: car wont start...please help
