Car Audio Help
Old 08-15-2010, 10:03 AM
Gr0dy's Avatar
Gr0dy has disabled reputation
Default Car Audio Help
A buddy of mine wants me to put some subs and an amp in his car. He's got 2 JL W3s (10 inch 2 ohms) and a pyle red elite PLA4180 4 channel amp. Specs for the amp are HERE . I was planning on bridging the amp to get more power, it's 125w rms per channel at 4 ohms so 250 rms x 2 if i bridge it. My only concern is that the subs are 2 ohms. My question is would i be able to bridge it still? If not, can i even use these subs with this amp? If i can how would i have to connect it? Thanks in advance
EDIT:: I found out its only 2 ohm stable in stereo mode, and not in bridged mode. What would be the best way to connect these to get the most power?
Gr0dy is offline
Old 08-15-2010, 11:51 AM
Default Re: Car Audio Help
if you want to bridge down to 2 channels, you'll need 4 ohm subs. If you want to keep the 2 ohm subs, you can run 2 channels at 2 ohms each and not use the other 2 channels. Or, you could connect the subs in series for a single 4 ohm load, and bridge 2 channels to that, also not using the other 2 channels.
Old 08-15-2010, 02:58 PM
Gr0dy's Avatar
alright thanks man
Gr0dy is offline
Old 08-15-2010, 03:29 PM
Tell your buddy to get a beefy set of front components to use the other two amp channels. 125W per channel should do quite nicely.
O Rly?
07-08-2006 11:19 AM
crx2sol
07-21-2005 08:01 AM
japspec4g63
04-15-2005 08:35 AM
japspec4g63
04-11-2005 02:37 PM
SHOFEAR94
12-06-2004 12:16 PM
Quick Reply: Car Audio Help
