burent valves=smokey motor??
can burent valves make a motor smoke,im trying to figure out why my past 2 motors have started to smoke which means i need to know if valves can cause a motor to smoke,or is it strictly rings and valve seals??
Re: burent valves=smokey motor??
well have you done a compression test? aron informed me on mine to dump a cap full of oil thru spark hole...do a compression test again...if you get some psi...then its the rings...if still no comnpression..its in the head. peace
Bad valve seals, worn rings or broken pistons is what normally causes smoke, burnt valves will normally cause low or no compression.
corona connessuer
how many miles are on the past 2 motors? also what mods have you done to said motors?
ohh no the motor ran great,strong compression and no loss in power,and basically stock motors with intake and exhaust and 2 layer headgaskets
corona connessuer
lol..trying to raise compression? dont cometic make high CR gaskets to? i know they make nice thick ones. hope ya aint pullin layers out OEM
got some fake hp
