Built engine: 80-175-90-180 What's wrong?
Old 03-07-2006, 08:23 PM
psycho jungle cat
Spindrift's Avatar
Default Built engine: 80-175-90-180 What's wrong?
What's wrong with this engine? The block has 19 miles, the head has zero (0) miles. Before my motor first went down (11/2005) it tested 210-210-210-210 and that was when HKS 272's were in. Since then, I've sold the 272's to fix the engine. I've installed & re-installed the head twice in the past two days.
DAy1: 80-175-90-180
DAy2: 80-180-80-180
Pistons 1 (80) & 3 (80)have oil on top of them, 2 (180) & 4 (180) are clean... no coolant.
What could it be? I'm about ready to throw in the towel.
-Citium2012
BTW, this is a 4G63T using Cometic HP HG... I JUST got the head from Abacus.
Spindrift is offline
Old 03-07-2006, 09:24 PM
Default Re: Built engine: 80-175-90-180 What's wrong?
What's the rest of the story? What did you have done at Abacus? Why did you send it to Abacus?
Old 03-08-2006, 02:24 AM
accuracy1's Avatar
accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1 accuracy1
chris get the car to the shop
accuracy1 is offline
Old 03-08-2006, 02:50 AM
sup
SCOOBY STEVE's Avatar
SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE SCOOBY STEVE
SCOOBY STEVE is offline
Old 03-08-2006, 02:58 AM
blu99teg's Avatar
blu99teg is on a distinguished road
Sounds like there is something wrong with the head? Maybe valves or something? You sure it had NO miles on it? Or was it rebuilt?
blu99teg is offline
Old 03-08-2006, 06:16 AM
holla
j4k3's Avatar
chris, that car better be some sex when its done cuz its starting to piss me off now. i'll ask my teacher today if he has any input on that.
j4k3 is offline
Old 03-08-2006, 06:23 AM
Boost is Better
sircrx's Avatar
sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx sircrx
bent valves or timing is off
if your 100% positive the valves arent bent make positive that your timing is correct the valves may be opening at the wrong times.
sircrx is offline
Old 03-08-2006, 06:34 AM
I'm still slow.....
ZeroMR's Avatar
ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR ZeroMR
Bad rings maybe, are those new rings?
ZeroMR is offline
Old 03-08-2006, 08:09 AM
braap braap
Jarrod's Avatar
Can't a bad valve adjustment make compression go down some?
Accuracy
Jarrod is offline
Old 03-08-2006, 08:13 AM
I'm still slow.....
ZeroMR's Avatar
Have you been using the same headgasket? Since you took the head off a few times.
ZeroMR is offline
Quick Reply: Built engine: 80-175-90-180 What's wrong?
