Brake Lights...
Okay well I have replaced the bulbs.. Which were bad... Didnt work..
Replaced the fuses.. Didnt work.. Any ideas where to go from here? |
Re: Brake Lights...
Do the running lights turn on? Try and take a look at the brake switch and see if its damaged or not.
Re: Brake Lights...
What is the actual problem you're having?
Your post sounds like this: I put a new shirt on. Didn't fix it. I found a red sock instead of blue. Still broken. What is the actual problem you're trying to solve?????? By the way, usually the first step in most problem solving strategies is "Define the Problem"... |
