boosted d16 wont start? help!
so while i was reconnecting my charge piping that blew off, my friend unplugged the fuel pressure regulator vacuum hose and forgot to put it back on. we tried to start the car about 3 times with it unplugged and idled terribly, would rev past 2k and was misfiring. so i plugged it back up and let it sit over nite to let the flooded fuel drain, and this morning it was still doing the same thing. so i disconnected the battery and after a minute tried it again and now it wont start at all. it sounds like trying to start a car with a dead battery..? its a d16y8 on a chipped p28 with 450 cc injectors and walbro 255. anybody have any suggestions.?
update- i pulled the plugs and they were pitch black, so the few times it did start, i was runnin real rich. put new plugs in, theyre all getting spark. charged the battery. motor cranks but doesnt start. fuel pump primes. what should i check next? i know its not my injectors cuz the car was running right before it all of a sudden stopped..?
Re: boosted d16 wont start? help!
yeas theres a cel. im gonna check it in about an hour. being that the ecu is obd1, i cant jus pull the code with the meter. its jus on a basemap right now im trying to get it running to get it to the tuner. the jumper is fine. the car was running about 20 mins before the charge piping blew. after that it ran terribly and misfired and after disconnecting battery, it wont start. map sensor and witing was never touched
Ramey Built
Heres a link to honda-tech that shows you exactly how to do it and how to read the codes.
http://honda-tech.com/showthread.php?t=1901557
Justin
