boost cut at 4000rpm in every gear
Just recently installed a t3t4 with a mini ram and open 3 inch down pipe 440 rc's as well as phearable base map.If anyone has any ideas as to what might be wrong please respond to thread.
Re: boost cut at 4000rpm in every gear
What car? What engine? What amount of boost? Why are you going to 4000 RPM in every gear on a base map before being tuned?
Originally Posted by Fabrik8
(Post 8112800)
Only a honda faggot would describe his turbo as a t3t4
map sensor?
sounds like your base tune isnt set up for boost.. |
Originally Posted by boostjunkie
(Post 8113527)
I don't even.
/handatards |
Originally Posted by Lord Humongous
(Post 8112813)
Because motherfucking race car
(Post 8113540)
Yes, probably MAP sensor cutting out at 11 psi or whatever the OEM MAP sensor flatlines at.. And it sounds like the base tune is a base tune, not a tuned tune.
when the ecu isnt setup to delete the map sensor readings it cuts as soon as it gets positive pressure that it cant comprehend.. which isnt even 1 psi.. if he had the old school missing link setup then it wont cut boost because it wont ever read positive pressure.. |
