Blown Head gasket
Old 10-16-2003, 01:40 PM
The Wizard
TempestRex's Avatar
TempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to allTempestRex is a name known to all
Default Blown Head gasket
Could a blown head gasket throw a Map sensor code? Just wondering cuz my car is acting real funny since ive fixed the starter problem. I do have a Y8/A6 mini me so any info would be appreciated.
TempestRex is offline
Old 10-16-2003, 01:45 PM
nickyroo's Avatar
your car will be runnin hot as hell if you have a blown head gasket. one way to check is to drain your oil and look for antifreeze in it, it will have a milky color to it.
nickyroo is offline
Old 10-16-2003, 02:20 PM
The Wizard
TempestRex's Avatar
o yea and cylinder 2 isnt firing. Any ideas?
Old 10-16-2003, 03:05 PM
nickyroo's Avatar
cylinder 2 not firing will cause you some problems
if i was you, id start by rescanning the car for codes. check all your plugs, make sure there are no slits or burnt spots on your wires. change them while theyre off. replace your cap and rotor on your distributor and go from there. did you disconnect your battery when working on your starter?
nickyroo is offline
Old 10-20-2003, 05:59 PM
The Wizard
TempestRex's Avatar
Old 10-21-2003, 08:34 AM
Iridium V
MGBRaceman's Avatar
MGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond reputeMGBRaceman has a reputation beyond repute
The no 2 cylinder isn't firing? Well if you think you have a blown head gasket you may want to check your compression.
MGBRaceman is offline
sive ick
06-22-2007 04:35 AM
b16efhatch
01-09-2007 10:14 AM
Enigma
03-29-2004 04:53 AM
tropic
10-29-2003 07:27 PM
Quick Reply: Blown Head gasket
