blown head gasket????
ok, so I put a b16a in my 89 si hatch and the first time the gasket was put on upside down. so I sent the head to the machine shop and they fixed the head. I finally got around to putting the head back on today. I put the timing belt on and I couldnt get it to tighten, and at the same time I had 2 of the plug wires swithed around. I fixed the plug wires and got the timing belt to tighten after a long attempt of trying to get it to start. Well I got it to start and it runs but horribly rough and know the head gasket is blown(has a white milky texture to it) and Im not sure why. does anyone know what could have happened
Re: blown head gasket????
it is also throwing an engie code, its #5
did you torque the head to the right specs
yes everything was torqued properly(head, cam caps,rods mains...ect)
did you put the same head gasket back on it? the one that you took off that was upside down?
your prob off time reall bad and compression is all screwed up
You need a new head gasket. Can't re-use the other one.
Originally Posted by EvolutionBoostin
(Post 2713030)
put nwe head gasket on and car is timed properly
Originally Posted by b16efhatch
(Post 2713001)
