Battery Tender question
GLHF
I'm looking at buying one to use between my Camaro and my motorcycle, until the bike sells, then it will just be for the camaro. Both batteries are 12v. I have browsed their web site, and sent them an email with the question, but so far no response.
To the best of my understanding, The difference between the BT Plus and BT Jr. is the amperage. 1.25 for the plus, and .75 for the Jr. These will both do the job of charging the motorcycle and the car, correct? The only thing different is the .75 will take longer to charge than the 1.25, correct?
superuser
Re: Battery Tender question
I'd recommend getting a microprocessor controlled one that can handle Optima batteries as well as auto/motorcycle ones. This model is the one I use for charging everything (car, camper, Optima, gel-cell, tractor, etc). Trickle charge, rapid charge, and start. $80 at Sears.
http://www.sears.com/diehard-micropr...p-02871225000P
GLHF
GLHF
superuser
personally, i just connect a trickle charger every few months to my spare batteries and start up vehicles at least once a month to keep them lubricated with oil.
GLHF
the one i posted does do maintenance thing, too. the microprocessor adjusts the voltage so that it does not overcharge and shuts off the charging once it reaches full capacity.
armed teetotaler
Batteries Plus has these all day. Google can find you a dozen other places that have it. It's more of a straight forward charger than a trickle. I put it on my bike a couple hours a week during the colder months because cold starts at 6am murder my battery.
If all you need is a trickle charger for maintanance during storage, either BT charger will work fine. The charging amperage is the sustained current that the charger can put out. If the battery voltage is past a certain level, the charge current will be much lower than that. So assuming that the battery is pretty well charged when you put the trickle charger on it, you would only need the smaller one. If some top-off charge is needed, the smaller one will just take longer than the larger one. That really won't matter though if the vehicles are in storage, because you have lots of time.
I've got these two tenders that I use....1 for the Camaro that stays inside and the other for the Camaro that stays outside....they have worked great!
This is the one I use outside.
This is the one I use inside.
