b20v not spraying fuel..??
Old 02-21-2012, 07:45 AM
GSRswapEk's Avatar
GSRswapEk has disabled reputation
Default b20v not spraying fuel..??
I have a b20vtec 12.5:1 compression, for some reason its not spraying fuel so it won't start,. I have changed resistor box, main relay, had the ecu checked, new injectors (450cc), new spark plugs, the fuel pump kicks on and the fuel rail has fuel and pressure in it but injectors won't spray, had some of the wiring checked and the basics have power. The car will start when fuel is manually poured in, so has to be fuel related. anybody have any suggestions? Anything helps , thanks!
GSRswapEk is offline
Old 02-21-2012, 10:05 AM
Default Re: b20v not spraying fuel..??
Make sure the resistors are supposed to be used with a resistor box. If the ECU isn't firing the injectors then the ECU isn't happy about something, or the resistor box isn't wired properly, or the injectors aren't wired properly, or the injectors don't have power.
You'll also need something other than the stock fueling maps if you want to use larger-than-stock injectors. That's something unrelated to the injectors firing, but the fact is that you aren't going to be able to use the stock ECU calibration with larger injectors.
Old 02-22-2012, 05:07 AM
GSRswapEk's Avatar
It's a fully built car tuned on s300.. they r dsm 450cc which require a resistor box.. injectorss have power and box is wired correct..it was running I shut it off , put alternator or my suv and then civic wouldn't start, now I'm stuck
Old 02-22-2012, 06:06 AM
Previously Odyssey
Odysseus Prime's Avatar
Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime Odysseus Prime
No idea with Honda's, but I've seen Nissan SR engines with this issue.
Problem was the grounds for the injectors.
Odysseus Prime is offline
Old 02-22-2012, 10:33 AM
GSRswapEk's Avatar
^ checked that, the grounds were good.
Old 02-23-2012, 09:39 AM
GSRswapEk's Avatar
Bump!.. the car is wire tucked, debating on putting whole new harness in it.
Old 02-24-2012, 09:22 AM
WheelPowerRacin's Avatar
WheelPowerRacin has disabled reputation
All your injectors should be hot (12v) with the ignition on. The ECU opens the injector to spray by completing the circuit to ground. So you should not have continuity to ground at the injectors unless the car is running, & then it would be intermittent as the ECU fired each injector. Generally with a wire tuck the opposite problem occurs, a wire grounds going through a hole in a body panel without a grommet, causing the injector to constantly spray.
WheelPowerRacin is offline
Old 02-24-2012, 11:49 AM
Oops, I misread that. Nevermind.
Old 02-28-2012, 10:20 AM
GSRswapEk's Avatar
thanks guys,... any other suggestions?
Old 03-05-2012, 04:45 PM
civic530hp_pump's Avatar
civic530hp_pump has disabled reputation
Take a low resistance test light and check the injectors for one wire 12v and other ground pulse when whirling motor over to determine what's missing first. Also a lack of good ground contact on frame to motor or harness to thermostat housing can play a part in it. Send me shout out if anything more is needed and I can help more
civic530hp_pump is offline
Quick Reply: b20v not spraying fuel..??
