b20 vtec idle issue choking up please help!!!
Old 07-28-2013, 05:01 PM
cstout7 has disabled reputation
Default b20 vtec idle issue choking up please help!!!
I have in my integra a n/a b20vtec build. B20z block and gsr head with b16 cams 11.2.1 compression valve train all that. I have a victor x edelbrock mani with blox 70mm tb and new fuel filter/fuel rail/injectors. The issue I'm having is on going but 1 out of 5 times I drive there is no issue but mostly it is ongoing. The issue is that when I sit at idle my car*idles at 900 but will consistently drop to 100 and jump back up to 900. The lights dim when this happens and it happens at red lights and whenever idling. Sometimes it does it sometimes it doesn't. Also while driving it will do the same thing only it will go from 3000 rpm to 100 then shoot back up. Like it chokes for a second then releases back. It jerks the car back for split second. I have cleaned iacv and bled my coolant for air bubbles. I ordered walboro 255 fuel pump today as well. I don't think my intake mani has an fitv. Any ideas guys? Please help!
cstout7 is offline
Old 07-28-2013, 05:53 PM
Default Re: b20 vtec idle issue choking up please help!!!
What ECU are you using, and have you got tuned? A "base map" doesn't count. That's not a tune, that's a basemap.
Old 07-29-2013, 06:18 AM
Hondata s300 tuned by millenium
cstout7 is offline
Old 07-29-2013, 06:23 AM
power2weight's Avatar
power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight power2weight
Vacuum leak? Injector o rings?
power2weight is offline
h2okilla3
01-20-2010 04:33 PM
00_VIP_BENZ
11-18-2009 04:37 PM
eglsvtec
02-18-2006 02:22 PM
RatedV
08-19-2004 11:50 AM
Quick Reply: b20 vtec idle issue choking up please help!!!
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
