b18b1 start-up problem!
Old 08-17-2010, 10:33 AM
Sellmesomething's Avatar
Sellmesomething Sellmesomething Sellmesomething Sellmesomething Sellmesomething Sellmesomething
Default b18b1 start-up problem!
When i first got the car when you first started it up after leaving it alone for awhile it kinda did a sputter bog until i hit the gas for a few seconds then it would idle/drive just fine. I left it alone for a few days and when to go start it the other day and it cranks but doesnt want to turn. Could it be a injector or rather a fuel pump problem?
Sellmesomething is offline
Old 08-17-2010, 02:55 PM
DOHCda's Avatar
DOHCda has disabled reputation
Default Re: b18b1 start-up problem!
Cranks but doesnt want to turn?? Sounds like a dying battery if i would have to guess need specifics. Does it sound like somethings clicking or does it turnover at regular speed??
DOHCda is offline
Old 08-17-2010, 02:56 PM
DOHCda's Avatar
Also sounds like a possible head gasket. Water in cyl would slow the cranking significantly but it would be smoking bad if it was like that.
DOHCda is offline
Old 08-17-2010, 03:07 PM
breath
tucker5129's Avatar
tucker5129 tucker5129 tucker5129 tucker5129
thats a pretty rash assessment lol. if its turning over at reg speed just not firing i would look into ur fuel system. get some ether and shoot it in past ur TB (not to much) then see if it fires. if it fires then dies right out it sounds like u have a fuel problem.
tucker5129 is offline
Old 08-17-2010, 03:17 PM
DOHCda's Avatar
Its a very bland explanation he says it cranks but doesnt turn, so starter, hydrolock, or battery only 3 things to cause a slow crank
DOHCda is offline
Old 08-17-2010, 06:53 PM
breath
tucker5129's Avatar
he never said slow turn. we need details in order to help u out!!!
Old 08-17-2010, 06:58 PM
CPL Us Army
jpick_aap_cpp's Avatar
jpick_aap_cpp has disabled reputation
injector i doubt thats the problem. Fuel pump wouldnt go BAD from just sitting around. How long did it sit? Bad gas in the tank possibly? plus if the fuel pump was the cause it would not start at all. Do you have full spark?! no archin due to faulty wires or have you checked to make sure the plugs arent faulty....
Check the basics.. Battery, spark, fuel...
jpick_aap_cpp is offline
Old 08-18-2010, 07:01 AM
tatum31's Avatar
tatum31 tatum31 tatum31 tatum31 tatum31 tatum31 tatum31 tatum31 tatum31 tatum31
same thing happened to me, go get your batterie checked and advanced. They did mine and i found that my volts were 10.388 and i didnt even have a cold crank. They usually have used batteries if your hard on money for the moment for around $35.00
tatum31 is offline
Old 08-23-2010, 03:58 PM
Built iT
Jdmhore's Avatar
Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore Jdmhore
check all of your grounds and main relay!
Jdmhore is offline
Old 08-23-2010, 05:11 PM
BallinthaEF's Avatar
BallinthaEF BallinthaEF BallinthaEF
x2
BallinthaEF is offline
Quick Reply: b18b1 start-up problem!
