-   -   B18b1 ??????? (https://www.vadriven.com/forums/tech-talk-9/b18b1-13147/)
5150 Apr 20, 2003 03:04 PM
B18b1 ???????
anyone know how much hp and torque the bottom end and tranny can take with out breakin somthin............I'm lookin to push close to 300 hp with various mods...no turbo..
Bert Apr 21, 2003 02:54 PM
300hp no turbo?...you aren't going to acheive that all motor unless you spray...i really not sure on the capacity of the b18b but i know the crank is strong and can handle 400hp...the sleeves, rods, pistons, etc are another story...
MORE IMPATIENT Apr 21, 2003 03:32 PM
have fun making 300 hp on an all motor ls, i really dont even think that is possible, well, everything is possible, but once again, have fun and good luck, your gonna need it...........
MA-HALF-E Apr 21, 2003 03:33 PM
Spray /= all motor
Pretty much what he said.
5150 Apr 22, 2003 03:12 AM
upgrades
Flatlander stage 2 head job, crane cams, aem gears, skunk 2 with bbk 65mm tb, tb swirl spacer,aem rail, injectors,regulator, custom ram air system "uses dry ice to drop intake air temp" , hi pro ign, dc longtubes, custom dual exhaust, crank underdrive, lsd install, zex, if this don't work ill try somethin else...
thanks for the input
CHAHONDA Apr 22, 2003 06:35 AM
YES.........nitrous is good!!!:D
Gold Eg Apr 22, 2003 07:04 AM
with nitrous the 300hp mark isn't too far fetched!
Bert Apr 22, 2003 09:39 AM
obviously if you spray you won't be all motor...what i meant to say was the only way to acheive 300hp is to spray...oopss...
Durrett Syndrom Apr 22, 2003 11:01 AM
Re: upgrades
can u explain this....sounds like one of those home made pointless mods. and also anything of to much is bad, wat if you freeze your motor or it will take 3 years to get it warmed up
Slow CX Apr 22, 2003 01:06 PM
Re: upgrades
custom dual exhaust
:crazy:
