B16 Problem
Old 12-08-2009, 10:23 AM
180sx2fast4u's Avatar
180sx2fast4u is an unknown quantity at this point
Default B16 Problem
I just swapped a jdm B16 into my 90 integra. Motor went in great and started up fine. When i went to pull it out of my garage I noticed i couldnt get the car in first gear. After inspection i realized that the shifter is tilted toward the driver side and the console is stopping the shifter from going into first and second. I checked the linkage and everything looks to connected properly. Did i do something wrong or is there something I dont know. If anyone has had this problem or knows the solution let me know. Thanks
180sx2fast4u is offline
Old 12-09-2009, 06:32 PM
LOLH8RS
straightHYPE's Avatar
straightHYPE has disabled reputation
Default Re: B16 Problem
did you use the same tranny and shift linkage?
straightHYPE is offline
Old 12-09-2009, 06:43 PM
Same linkage, different trans
Old 12-09-2009, 06:47 PM
LOLH8RS
what trans are you using ?and is it cable or hydraulic
Old 12-09-2009, 06:51 PM
Cable, whatever came on the jdm b16
Old 12-09-2009, 07:19 PM
LOLH8RS
the tranny shifts fine out does it give u problems in any other gear
Old 12-09-2009, 07:30 PM
If the center console was out I could get to all gears, right now third is in firsts place and 5th is in 3rds
Old 12-09-2009, 07:47 PM
LOLH8RS
wow um i guess take the shift linkage out check it if anything it could be the tranny internal shifter is bent
Old 12-09-2009, 07:51 PM
Yeah I'm gonna check it saturday, ill let u know the outcome
Old 12-09-2009, 07:53 PM
DeFunk's Avatar
DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk DeFunk
Does the gear shift feel more loose than you are used to, does it wiggle side to side when in gear?
DeFunk is offline
Subie2Honda
01-16-2009 01:07 PM
singlecam4life
09-07-2008 02:05 PM
vaspeedjunky
03-22-2006 05:09 AM
94 Teggy
12-27-2004 09:36 AM
EG1sol
10-16-2004 07:27 PM
Quick Reply: B16 Problem
