B16 CRX Limp Mode Problem
Old 10-20-2004, 04:10 AM
94 Teggy's Avatar
94 Teggy is an unknown quantity at this point
Default B16 CRX Limp Mode Problem
Its throwing a code 6, coolant temp sensor right? PR3 Chipped In B16 CRX, in limp mode, about 6K redline. I replaced the sensor, but I'm still getting code 6, DAMMIT, please help.
94 Teggy is offline
Old 10-20-2004, 07:51 AM
"Mod Everything"
j.i.g.'s Avatar
j.i.g. has disabled reputation
Default Re: B16 CRX Limp Mode Problem
Is this a new swap or was it running at one point?
j.i.g. is offline
Old 10-20-2004, 08:42 AM
94 Teggy's Avatar
It DID work fine, until 2 days ago. So yes, it was running at one point.
94 Teggy is offline
Old 10-20-2004, 09:29 AM
Runnin13s's Avatar
Runnin13s is on a distinguished road
well if it was a new swap ..for some reason i have done 3 b16 swaps in crx and they all threw code 6 for some odd reason ..and the only way to fix it would be to un hook my reverse lights from my transmission...sounds weird but beleive it or notevery time i hooked them up it through the coolant sensor code ..oww and it only did this in an HF not an si or anything else for sum reason ?? iono
Runnin13s is offline
Old 10-20-2004, 10:58 AM
94 Teggy's Avatar
It is an HF, and thank you very much, I will try that and let you know if it works. Fucking wierd, I never would have thought of that. After I disconnect them, can I hook back up, or not?
94 Teggy is offline
Old 10-20-2004, 01:40 PM
calgone47's Avatar
calgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond reputecalgone47 has a reputation beyond repute
Cut the wire going into B9 on the ecu, should be green/black, that will work and no you do not hook it back up.
calgone47 is offline
Old 10-20-2004, 03:05 PM
94 Teggy's Avatar
I just pulled the plug on the front of tranny for backup light and it worked. I don't trust myself to cut wires, I'll fuck something up. Thanks for your help.
94 Teggy is offline
Old 10-20-2004, 03:23 PM
Runnin13s's Avatar
lol for some odd reason i knbew thats what it was but its weird as hell how that works ...exspecially since u said the swap was running fine
Old 10-21-2004, 08:12 PM
FUCK THIEVES
G2 LS-Vtec's Avatar
G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec G2 LS-Vtec
THATS THE BIGGEST BULLSHIT I'VE EVER HEARD....
...but i had the same problem with a rev limit at 7600, no codes though, i unplugged my reverse switch too and it raised the rev limit to normal. I was like haha wtf, all this time I could have fixed it by this stupid shit. thanks
btw, its a b16 swap in place of the old ls-vtec in an OBD-0 DA integra
G2 LS-Vtec is offline
nosediv3
12-05-2008 12:56 PM
jaccord95
07-31-2008 09:14 PM
JAPCO
02-24-2007 04:49 PM
ONYX787
11-07-2005 03:14 PM
xk84f9ds
10-17-2004 05:10 PM
Quick Reply: B16 CRX Limp Mode Problem
