b series coolant system help
DESTROYS DONUTS !!
Re: b series coolant system help
was pretty sure that goes to the FIT valve.
if you have an aftermarket intake manifold, like skunk 2. you can bypass it.
DESTROYS DONUTS !!
hold on real quick. i was thinking of a d series.on a d series theres a little nipple on the water neck by where the lower radiator hose enters the thermostat housing, that goes to the fit valve.
. if you are referring to the upper radiator hose. that its next too, than that is a main heater hose and will connect to your heater control thats mounted near the firewall.
Bringin Dwn the Rice
heater core line is what im guessing since that is the hose that broke in my car and it will pour antifreeze or water what ever kind of liquid is in your radiator. get a new hose and clamps and call it a day if you still have issues get an aluminum radiator........
for alarms/rmt-strts
oh i was trying to fix the wiring problems first but yea ill buy the hose tomorrow but my friend had pointed out while he was doing my wiring and where it should go ive just been crazy busy putting alarms in and ATTEMPTING to do my own wiring
