98 integra power steering problem
Old 10-28-2013, 10:09 PM
91fastback's Avatar
91fastback has disabled reputation
Default 98 integra power steering problem
So my car is making the noise when its low on power steering fluid. So I put some in the reservoir and is still making the noise. Just looking for some information on what it could be
91fastback is offline
Old 10-28-2013, 10:26 PM
mikejones002100's Avatar
mikejones002100 has disabled reputation
Default Re: 98 integra power steering problem
It could be the pump going bad... They are prone to go bad and burn up when low on fluid ..
mikejones002100 is offline
Old 10-29-2013, 09:14 AM
See if the belt needs replacing too. I don't really know which noise you're talking about though. Is it noisy during turning or noisy all the way at the end of the rack travel or noisy all the time?
Old 10-29-2013, 10:08 AM
RiverCitySyn
brandini's Avatar
You may also have an air bubble in the pump and/or lines and it may take a bit to work it's way out so keep on top of filling it up and if it never stops losing fluid... time to look for a leak.
brandini is offline
Old 11-09-2013, 08:23 PM
00_civic757's Avatar
00_civic757 has disabled reputation
try changing out the O-rings for the high pressure feed line(from pump to rack) and the lower hose(from reservoir to pump) - its possible that they are dry rotted and allowing air to get into the system - I changed these out a lot at work on all different models of acuras and the noise will go away majority of the time - try looking at your fluid while the car is running and/or turning the wheel and see if the p/s fluid is bubbly at all - if so u have air in ur system
00_civic757 is offline
Old 11-10-2013, 06:48 AM
Which system is the ur system? Never heard of that one.
95DCTEGGY
04-02-2007 08:41 AM
1995JettaIIIGLS
06-10-2004 06:24 AM
Quick Reply: 98 integra power steering problem
