98 civic, auto to manual and b series swap starts then dies
Old 03-09-2011, 07:44 AM
civicrider's Avatar
civicrider has disabled reputation
Default 98 civic, auto to manual and b series swap starts then dies
Problems are in RED.
Swapped a B16a2 bottom end/gsr head with gsr tranny into my friends 98 civic ex auto last night and now the car won't stay running. It will run for 1-5 seconds tops before stalling/cutting off (giving it gas doesn't help). No CEL's. IACV will start humming/making noise after attempting to start it. Swapped it out for another IACV and it does the same thing.
Ignition will not release the key also.
-converted from 3 wire to 2 wire IAC and repinned the A plug on the harness
-Installed proper plug for IAT on IM
-Running on a obd2a gsr ecu.
-2 big wires are tied together where the auto shifter used to be
-Car is in park
-Swap ran in ek that I pulled it out of before installing in this car.
Any help is appreciated in advance.
civicrider is offline
Old 03-09-2011, 12:31 PM
its just a website
couped's Avatar
couped couped couped couped couped couped couped couped couped couped couped
Default Re: 98 civic, auto to manual and b series swap starts then dies
because of swap..just look at things you could've carelessly mistaken--
any smoke or bogging down when running? - crossed hoses
follow the ignition key problem starting with the wheel itself all the way down the column to the axles
im not sure if these problems are related but glwf
couped is offline
Old 03-10-2011, 05:48 AM
civicrider's Avatar
swapped map sensors yesterday now the car idles fine but bogs down everytime you give it gas
-tps was replaced and installed correctly
Old 04-17-2011, 05:30 PM
sweethatch1866's Avatar
sweethatch1866 has disabled reputation
on auto chassis the map sensor plug is not in the wiring harness. the plug you need to use runs behind the battery and along the firewall. dont use the one on your engine harness. had the same problem
sweethatch1866 is offline
Old 04-18-2011, 09:45 AM
civicrider's Avatar
lol.. problem is fixed and I'm pretty sure the the plug for the map is on the engine harness
da93teg
Engine / Exhaust / Drivetrain
02-17-2011 02:41 PM
pt0wn_4door
04-24-2008 08:12 AM
93VAHatch
02-18-2006 11:05 AM
Quick Reply: 98 civic, auto to manual and b series swap starts then dies
