96 civic gsr swap help
hello ppl i have a 96 civic and i just swapped a 96 gsr in it i used the stock d series harness because it had the vtec plug on it and everything and the car does not crack vtec at all it runs perfectly beside a high idle i have a cel on but it for o2 sensor and ckp sensor but from what i have been told that stuff dont matter so if anybody can help me out that would be awsome.
Go cry to momma
Re: 96 civic gsr swap help
ok so can anyone tell me where to hook it up because i dont have a spot where it is supposed to go i have been told a bunch of different spot like make a spot on the alt. bracket or i also have been told that there is a spot under neath the number 2 intake runner
It's inside the distributor, just like every other fuel injected Honda engine ever made in the last 25-ish years.
And you really need to stop listening to people that tell you that the crank position sensor isn't important. It's a critical sensor.
And fix the O2 sensor too.
