95 integra gsr Axle removal/Swap
Tomorrow is the day i do my first engine swap its a B16a2 into a GSR shell. Got and engine lift coming in, and have a medium size tool bag (Will buy as needed). Couldn't find any instructions on how to do it on yahoo but i know i can pull it off! Only issue now is, I was told its hard to remove the axles. So, is Pulling the axles from the tranny necessary to pull engine out from one teg to another? If so, can i get some instructions on how to do it right?
Also anything important i have to now before i start the swap? Thanks for the help!
Re: 95 integra gsr Axle removal/Swap
you always have to remove axles when pullin ur engine out. I always remove the tps sensor as well when pullin the engine out . Its also easy to pull the motor out wired up if you unplug it from both strut towers. Do u know how to remove the axles.?
Yes im unplugging the harness from the harness around the strut tower, that should eliminate some work. I don't know how to remove the axles.
I suggest letting someone else do the motor swap if you arent able to pull the axles. But to be the nice guy i am, ill tell you. Leaving the wheels on, you need to break the hub nut off. You may need to unstake the nut. Part of the top of the nut will be bent into the nut to prevent it from spinning off. You will need to use a punch or something to bend it back out so you can get it off. Now take off your wheels. Then you need to undo the strut fork nuts so you can swing the strut assembly and pull the axle from the hub. Then you can pull/pry the axle from the transmission. They are usually hard to pull from the transmission and that might be the reason why you heard they were hard to do.
fuck this shit
whatever you do, try to keep the block and tranny connected. this will make it 10x easier to swap. trying to align tranny with block can suck balls....
to remove axles, lift car, support on jack stands, remove wheels, remove 32mm axle nut. impact wrench works great here. remove the upper and lower ball joint cotter pins, and the 2 17mm nuts. remove the 14mm brake hose to the caliper. start hitting shit til everything breaks loose. swing the hub out of the way, and you can even lift it out of the car to make more space.
next, take pry bar, wedge between axle cup and half shaft on driver side. start pulling. if that doesn't work, cut the inner boot, and prepare to get dirty, but clamp some vice grips over the cup, and hit repeatedly with a hammer.
on the passenger side, you should be able to use either technique above.
hope this helped.
hope this helped.
Dude, if u can't remove the axles then u deffinatly shouldn't be doing a swap... Its by far the easiest thing I have ever done in my life. My sister can do that shit, so I'm sure it will be easy for you. Have confidance in yourself and if anything get a helms book.
"SI"ngle Cam
08-21-2004 02:33 PM
