95 civic not gettin fuel
Old 05-11-2011, 05:56 PM
civicfreak1985's Avatar
civicfreak1985 has disabled reputation
Exclamation 95 civic not gettin fuel
hi guys i got a 95 civic im not gettin fuel to motor i just replaced the fuel rail an relay still nothin what else could it be
civicfreak1985 is offline
WEEEEEEEEEEE
TATTRAT's Avatar
Default Re: 95 civic not gettin fuel
you are out of gas.
TATTRAT is offline
Old 05-12-2011, 02:45 AM
wright's Avatar
^^^^^, fuel pump could be bad, or a bad filter.
wright is offline
Old 05-12-2011, 06:40 AM
Tunafish's Avatar
Tunafish Tunafish Tunafish Tunafish Tunafish Tunafish
If you haven't already, turn the car to "on" but don't start, listen for the fuel pump. If you don't hear it, there is one thing you could check.
Your fuel pump circuitry runs through your main relay, not in your fuse box.
A common problem especially with the change in the weather is the soldered connections in your main relay cracking away from the leads.
This happened to me last year just as it started to get warm.
A new relay is expensive, but you may be able to fix yours by prying of the plastic cover and re-soldering the connections. Been a year since I did mine, and it's still working fine.
Not saying that's what it is, just something to check.
Tunafish is offline
Old 05-12-2011, 09:10 AM
SPARKLEmotion
FObangah's Avatar
All of the above. Take the gas cap off, and have a friend put an ear to the fill hole while you turn the key over. It's not always easy to hear the fuel pump in the car, especially with the door closed, or it open and "key-dinging" in your ear.
Do this and let us know what you hear.
FObangah is offline
Old 05-12-2011, 06:09 PM
hey i put in a new fuel pump an relay an turn the key on to the on position an dont hear the fuel pump at all
Old 05-12-2011, 06:55 PM
ItIsWhatItIs
LoveMyLS's Avatar
LoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond repute
probably gonna want to check for signal at the ecu(P28).
A1-INJ1 INJECTOR#1 Brown, Battery Voltage with KOEO
A2-INJ4 INJECTOR#4 Yellow, Battery Voltage with KOEO
A3-INJ2 INJECTOR#2 Red, Battery Voltage with KOEO
A5-INJ3 INJECTOR#3 Blue, Battery Voltage with KOEO
A7-FLR1 fuel pump Grn/BLK, Battery Voltage with KOEO
If all that ^^^ tests out ok, check fuel pressure at fuel filter.
hope this helps
LoveMyLS is offline
Old 05-12-2011, 08:39 PM
certified asshole
crasy87rexsi's Avatar
crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi crasy87rexsi
dude idk why everyone says to listen for the pump...that thing has a mechanical fuel pump.
Check to make sure the ecu is getting power, mostly just see if the check engine light comes on then goes out when you turn the key on also make sure there is a bulb for the cel. Check grounds on the car, specifically the one on the thermostat housing, sand the contacts and re-attach it. And like guy above me said check for 12v but check at the ecu, at the pump and at the main relay.
crasy87rexsi is offline
Old 05-13-2011, 10:12 AM
SPARKLEmotion
FObangah's Avatar
You just lost any credibility you had. Might as well delete that shit in your sig.
FObangah is offline
Old 05-13-2011, 01:25 PM
certified asshole
:faceplam: you are a complete moron, apparently reading all of someones post is too much for you. Go back to hitting the bong dude and get off here.
Quick Reply: 95 civic not gettin fuel
