93 Acura Integra GSR stalls out and wont start back up....NEED HELP!!
Hey guys, I have a 93 Integra GSR that is down here at school with me (750 miles from home) and it has had no problems since I brought it down here. One night I go out to start it and it immediatley stalls out and dies in the parking space I'm in and wont start back up...it will crank but not turn over (all lights are working and not dim so I've kinda ruled out battery, alternator and of course starter because it has no problem cranking) I had my buddy try to jump me and it didnt make any difference the first few times i tried to crank it but after several times of trying, my car finally cranks up..It idles fine and i let it get up to operating temperature and everything seems to be alright now. The next morning I get in it to drive to work, it starts up fine again and I get about 200 yards down the road and the sucker just loses power and stalls on me and wont start back up...Again my buddy came and tried to jump me since it worked before but this time it took even longer to get my car fired back up but it finally did on like the 10th time and I quickly drove it back to my apartment with no issue...Has been sitting for 2 days now and I try to start it twice a day to see if it will still crank(and it does) im just scared to test drive it around because I know it will probably die on me again...I usually can diagnose most problems but am totally stumped here and have little to no time because Im busy at school but NEED my car. Can anybody help me? I can surely compensate anyone who can lead me to my problem...Thanks in advance guys...
Re: 93 Acura Integra GSR stalls out and wont start back up....NEED HELP!!
Ah, the joys of taking a 22-year old car to school with you.
Think carefully about the ambient temperature when you're having problems. Has this just started since it's been significantly colder outside, you mentioned the mornings were an issue. |
missing a couple teeth on the flywheel maybe, that could give you intermitant starting issues
does it sound like the starter is engaging but the motor isn't turning over? |
When it did start, did it run any differently than it normally does? If it ran fine, it doesnt sound like a timing belt issue. How many miles are on the belt?
I had a lot of issues with my fuel pump before I finally replaced it. My car never stalled out while it was running, but it would sometimes not fire up after being parked. Unhooking and draining the pump surprisingly got me going quite a few times before it finally quit.
Originally Posted by Niburu
(Post 8324365)
Originally Posted by Mirrorimg
(Post 8324430)
I had a lot of issues with my fuel pump before I finally replaced it. My car never stalled out while it was running, but it would sometimes not fire up after being parked. Unhooking and draining the pump surprisingly got me going quite a few times before it finally quit. Doesn't sound like he has a problem cranking, it just doesn't start. |
it could be your battery. check your connections and grounds. clean them if you can.
Look save yourself some time and just put a volt meter to the battery, even if its enough for the lights doesn't always mean enough CCA or volts to start the car. However, from your brief description sounds like you have enough to start and run the car.
If it fires up then your alternator should recharge the battery before it dies out. They way your describing it cutting out, sounds like a fuel issue to me. So test your battery,yu should have done that first and see if thats an issue or eliminate that possibility. Another easy test is, check your fuel pressure and see where its at. You should have 48-56 psi @ the rail w/o vaccum and 39-46 w/ a vaccum on the sytem. The fuel pump should have 40psi Injector resistance is 10-13 ohms if your going to test that. |
I had similar problem a year or two ago. ended up being a ground had bad connection.
the ground near your starter? I replaced the air filter, fuel filter and all spark plugs yesterday and I drove it to work this morning without any problems...hopefully one of those was my problem. The spark plugs were black as hell and both filters were a little clogged. The fuel filter had dirty fuel coming out of it and the air filter hadnt been changed in about 5 years...oops
Originally Posted by Stryker16272
(Post 8326053)
