93 accord no start *help*
So my 93 Honda accord will not start unless I jump it off. I have had the battery tested and it is good, replaced the battery cables, I have a brand new starter and alternator but when I go to crank the car w/o jumping it all it does is click once and then nothing happens other than the lights going from very bright to extremely dim. Any thoughts or ideas?
Re: 93 accord no start *help*
Check the voltage drop between the ground terminal of the battery and the chassis using a voltmeter (yes, there will be voltage between different parts of a grounding system). You'll need a friend, because one of you will need to use the voltmeter while the other one turns the key. I think you'll find that you have a grounding problem.
