92 integra/ Starting problem
I have a 1992 integra 5 speed manual It won't start, battery,starter and fuses are all good. There is no power to the starter solenoid wire and there is no power to the safety clutch switch. I have looked for the starter relay and for what feeds the starter solenoid but can't find it.. Can anybody help
Re: 92 integra/ Starting problem
check the fuel injection relay (main relay) or ignition coil.
lower left hand side behind the dash , either a gray or black box says main relay on it.
there is a fuse under the dash that sits on a wire that looks like a cheap amp wire fuse. look for it and see if it is blown.
Main Fuel Relay.
I can start the car but not with the turn of the key. I think it may be the starter solenoid? but i dunno.
it happend on my vacation i went to the store the car started up just fine and i went in the store for 5 min and came back out and got in and tried to start it it wouldnt start. i have power but its not cranking to start. |
i had the same problem in my DA..i replaces the main relay...and it didnt mess up since
also if oyu have guages running wire from the engine bay to the inside make sure they arnt grounding out near the starter...had that happen in my hatch...
Ill see about replacing the main relay. i dont have wires running from the engine bay to the inside except for my cooling fan and its on a switch which i know for a fact that thats not the problem. but ill see about changing the main relay
main relay is good i checked the clutch safety switch thats good. umm i cant think of anything else.. its pissing me off. anyone got any other ideas. im tired of popn the hood everytime i wanna start the damn thing
