92 eg problems
Old 02-15-2010, 04:23 PM
98ektypeRhatch's Avatar
98ektypeRhatch has disabled reputation
Default 92 eg problems
im haveing trouble with my car i had a good running b16 in it i took it out of my car and put a gsr in it and and now its throwing code 21 and 41 and at idle its surging real bad i changed the iac valuve and it has a lil air leak on the throttle body gasket im trying to figure out why it is surging at low idle?
98ektypeRhatch is offline
Old 02-15-2010, 06:26 PM
wright's Avatar
Default Re: 92 eg problems
So, 21 is Vtec solenoid. Most likely you do not have it hooked up correctly. 41 is the O2 sensor. The main thing that you need to fix is the air leak on the TB gasket. Just so you know there is two different gaskets so take the TB to the parts store to make sure you get the correct one.
wright is offline
Old 02-17-2010, 05:25 PM
ItIsWhatItIs
LoveMyLS's Avatar
LoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond reputeLoveMyLS has a reputation beyond repute
vacuum leak will cause surging. vtec code shouldn't cause surging. are you using the engine bay harness from gsr?
LoveMyLS is offline
seanazzy
11-24-2006 06:05 PM
diggity dave
10-22-2006 12:55 PM
cleanEK
07-19-2006 12:00 AM
tp teddy
02-09-2006 07:21 PM
To0C0oL
09-16-2005 06:45 AM
Quick Reply: 92 eg problems
