89 Honda Accord (need some help)
Hey, my friends car wont start. it'll turn over and he said it'll get fuel and the fuel pumps working. also he said the Timing is set fine, (everything lines up, cap rotor is good...) i told him to check the coil pack but i dunno....if anyone got any advice lemme know :D thanks a lot guys.
-pat |
eh? no help?
Check for spark
Hey, you might wana check for spark, what you do is take the spark plug cables off and have someone crank over the engine while the spark plug cable is touching something metal like a bolt on the valve cover. Only do one cable at a time. Also check to make sure the spark plugs are good, make sure all rocker arms are on properly, make sure gas is in the engine. That should cover it.
-Aaron- |
hmmm..he said he was getting spark....fucking weird......godamn hondas....
-pat |
did you check and see?
Hey, did you check to see he was getting spark for sure? Try seeing if u can find someone else with the same car he has and swap parts out to see what part is screwed on his car, then put them back in the good car.
-Aaron- |
2 words, main relay. they are known for that.
thanks a lot!
-pat |
