89 civc 1.5 sohc fuel problem
Old 06-24-2004, 01:21 PM
3VOLVED
PSIDOFF's Avatar
PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF PSIDOFF
Default 89 civc 1.5 sohc fuel problem
rebuilt a 1.5 but now its not gettin fuel... anyone know anything they might wanna share here??? brand new fuel pump thats gettin power... relay is good been checked... fuel filters are not clogged now im stumped. No alarm or anything of the nature
PSIDOFF is offline
Old 06-24-2004, 02:11 PM
Bitches get Stitches
sk8rmike's Avatar
Default Re: 89 civc 1.5 sohc fuel problem
Got pressure at the rail? Loosen up the regulator and see if fuel sprays. If you're getting pressure there it has to be an injector problem. Are you using obd0 injectors? The resistor box still wired in?
sk8rmike is offline
Old 06-24-2004, 05:33 PM
NIC668's Avatar
If you need to check wiring or anything like that I am running a stock 1.5 never touched in my CRX. I would be more than happy to let you look it over.
NIC668 is offline
Old 06-25-2004, 08:01 AM
corona connessuer
CHAHONDA's Avatar
check your main relay
CHAHONDA is offline
Old 06-29-2004, 09:53 AM
3VOLVED
PSIDOFF's Avatar
checked themain relay under the dash... its good. The main problem is... we put a brand new fuel pump in, its gettin power but no fuel is goin down the line... checked the fuel filter in engine bay and no fuel is comin out.. now im at a loss here.. cant figure it out
PSIDOFF is offline
Old 06-30-2004, 04:58 AM
corona connessuer
CHAHONDA's Avatar
you didnt mix up the fuel lines to the pump did you?
CHAHONDA is offline
Old 06-30-2004, 02:26 PM
NIC668's Avatar
^ good point I did that once on a customers car...took me a few minutes to figure it out.
NIC668 is offline
Old 07-02-2004, 12:49 PM
3VOLVED
PSIDOFF's Avatar
little update... the voltage to the fuel pump is at 12volts when car is on the on position, soon as u go to turn it on, boom it drops to 2volts
PSIDOFF is offline
Old 07-02-2004, 02:44 PM
3VOLVED
PSIDOFF's Avatar
its done thanks for the help.... ended up being a wire grounding out
PSIDOFF is offline
BlacktopDET
01-25-2009 12:02 PM
BLU CIVIC
08-05-2008 09:09 PM
99whtneon
11-30-2007 07:15 PM
DirtyEF
10-29-2006 06:48 AM
MarkiSick
06-27-2004 07:15 PM
Quick Reply: 89 civc 1.5 sohc fuel problem
