73 Plymouth Valiant distributor problem
Old 08-06-2011, 07:48 PM
goggles do nothing
goosane's Avatar
goosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud ofgoosane has much to be proud of
Default 73 Plymouth Valiant distributor problem
Hi guys,
I recently inherited and started putting work into this old boat.
Among other things, I replaced most ignition system parts (new coil, ballast resistor, plugs, wires, distributor cap, rotor, diaphragm, pick-up coil assembly). While reinstalling the distributor, I turned the crankshaft to 0 tdc bringing cylinder 1 to the top end and aligned the rotor to HT wire no. 1(going to cylinder 1) per manual instructions.
I'm getting spark from the coil, but not from the distributor going to any plugs. Any idea of what I'm doing wrong, or what I should look out for? It was running before, but poorly. It turns now, but doesn't start.
Any help is appreciated.
Thanks starry bras
goosane is offline
Old 08-07-2011, 02:10 PM
goggles do nothing
goosane's Avatar
Default Re: 73 Plymouth Valiant distributor problem
*No spark from coil, checked ignition control unit.
Ballast resistor is giving incorrect ohm readings on terminal 1 & 2 test, but its brand new.
goosane is offline
1sloEX
08-07-2006 08:58 AM
mpg9999
11-23-2002 03:44 PM
growley
11-20-2002 09:02 AM
16g-95gsx
11-14-2002 02:16 PM
Quick Reply: 73 Plymouth Valiant distributor problem
