5 speed swap help (2g DSM)/ Shifter cable bushings
Formerly da_clipse
Swapped my 95 gs over to 5 speed a few months ago but have yet to find a wiring diagram for the ecu so that i can get my speedo sensor and reverse lights hooked up. Can anyone help me with this? The reverse sensor is a simple two wire setup and the speedo sensor has three i believe. I thought about just wiring the reverse lights to a switch but id rather just do things right.
I also need to know if the shifter cable bushings from the turbo and non turbo cables are the same. My bushing that controls the forward and back movement of the cables is torn to death and will only let me get first third and fifth. I can only get second and fourth when car is completely still. still cant get reverse.
I put some washers on top and bottom to help keep the cable from pushing up in the air but it only hepls in getting 2nd and 4th when sitting still. I've been told i can use the bearing from in-line skates but have yet to be able to get one out of the skates i have. Anywho back to the point i need to know if the bushing for turbo and non turbo are the same because i was gonna order these.
http://streettunedmotorsports.com/pa...earing_kit.htm
http://streettunedmotorsports.com/ds...drivetrain.htm
Any help would be greatly appreciated.
JdmLove
Want to Buy / Trade ARCHIVE
08-05-2008 08:38 PM
