240sx rear brake upgrade help.
im doing brake conversion i have a 26mm caliper from a 1990 300zx, wat do i need for the conversion and do i need to change the e brake cable. and also i have redrilled rotors so itll fit a 4 lug spindle. coz i was looking at this one thread that was talkin about changing "Obviously, there are the rotors and calipers. You will also need the e-brake cables, and the complete e-brake/splash shield setup." so i just need some feedback id really aprreciuate it alot thanks. http://www.importnut.net/300zxbrakeswap.htm
Never Blend In
This is going to spo
Re: 240sx rear brake upgrade help.
your bold type sums it up. You need all that shit...
gl finding the ebrake assys. It took me about 2 months to find some for a decent price.
ooo and im not doing a 5 lug conversion and i read on this one website that
"-S13 uses 30mm front hub bolt, S14 uses 32mm front hub bolt. Both chassis uses 36mm rear hub bolt.
-Conversion to 5 lug on S13 chassis requires S14SE/Z32nonturbo rear hubs, and either 1) JDM aftermarket front S13 5 lug hubs, or 2) S14 SE front hubs + S14 spindle + S14 ball joint w/LCA (and redrilling of strut for larger strut bolt)."
http://www2.freshalloy.com/showthread.php?t=57801
Speak&Spell Anyone?
WIKAP WIKAP PLBTTTTT
Honestly, I didn't want the hassle and expense of the rear brake swap. So, I just did the fronts. Here's a good read on braking bias for the 240sx: http://forums2.freshalloy.com/showth...ighlight=brake
It basically says front Z brakes INCREASE braking bias ~4.5%. Front and rear Z brakes DECREASE braking bias ~4%. Upgrading to a Z brake master cylinder will INCREASE braking bias ~1.5%.
