240sx electric fan issue
AMERICAN INFIDEL
the electric fan won't turn on.... it's a 90 sx, only thing is it has two (2) seperate connections going to the fan... want to hard wire it to a toggle switch so fan can be controlled manually... not sure which wires to splice to run to the toggle switch... any ideas?
you can call 757-437-1383 if you know anything
Re: 240sx electric fan issue
Check the fan switch (fan thermostat) on the engine, you may not need to ghetto rig a fan toggle switch if that's the problem.
WIKAP WIKAP PLBTTTTT
Previously Odyssey
Originally Posted by blaxican25
You could just wire the fan to be always on.
Just wire it to your ignition 1 wire ( Black w/ green stripe) found below the steereing wheel.
