2006 Malibu - No Start
Old 03-17-2015, 08:43 AM
cardana24's Avatar
cardana24 cardana24 cardana24 cardana24 cardana24 cardana24 cardana24 cardana24 cardana24 cardana24 cardana24
Default Re: 2006 Malibu - No Start
Does it maintain the 55 psi at the fuel rail while it's sputtering?
cardana24 is offline
Old 03-17-2015, 09:36 AM
Standartenführer
euthorus's Avatar
euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus euthorus
Sure does
euthorus is offline
Old 03-17-2015, 11:51 AM
cardana24's Avatar
have you ever seen the car run? I ask because I was having a similar issue when I bought a non running car a few months ago that turned out to be a clogged cat/exhaust. I had good fuel pressure, spark and compression.
Old 03-17-2015, 03:29 PM
AaronDavis
AaronDavis's Avatar
AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis AaronDavis
Do you have good compression? Also I would check for fuel injector pulse. I believe there's a big 20 pin or so connector located by the alternator that has all the fuel injector wiring so you won't have to pull the upper intake.
And in my first post, I was saying that the wires to the camshaft position sensor can sometimes chaff on the power steering pump if it has hydraulic steering. Being that yours is electric, it could still have a bad cam sensor, but the wires wouldn't be chaffed through.
AaronDavis is offline
Old 03-17-2015, 03:31 PM
AaronDavis
AaronDavis's Avatar
That's another possibility. If you suspect that, pull the precat oxygen sensor and see if it'll start.
Old 03-17-2015, 03:35 PM
Standartenführer
euthorus's Avatar
Hmm...is there a way to quick relieve the cat ? I do notice puffs of smoke from the throttle body since taking the intake boots off.
euthorus is offline
Old 03-17-2015, 03:37 PM
Standartenführer
euthorus's Avatar
Time to investigate, and no it never ran in front of me.
euthorus is offline
Standartenführer
euthorus's Avatar
Yup, first thing I pulled off after looking at the CPS. The wires are oldish but good contacts.
euthorus is offline
Old 03-17-2015, 04:12 PM
If it's one of the hatchbacks, just drive it into the lake and move on.
So ugly.
Old 03-17-2015, 05:19 PM
Standartenführer
euthorus's Avatar
So ugly.
LOL wish it were, it's a sedan
euthorus is offline
Quick Reply: 2006 Malibu - No Start
