1998 integra gsr engine grounding
Alright so I just bought a car and the realized that the front engine to radiator support ground was gone. The bolt that connects to radiator support was there. I went to go take the bolt off and it snapped easily(Rust). The thing is, is that it is a special bolt with a hole through the middle where a wire comes up from underneath connecting to the top bolt. Also the wire goes somewhere inside the firewall. Now I went to autozone and they didnt sell this special engine grounding mount and was wondering if I can just put a connector on the wire and straight bolt it to chassis. Will this make a performance issue or is everything going to be okay? Thanks in advance
Digital Life
Re: 1998 integra gsr engine grounding
Your post hurt my head after reading 2 lines into it, but if you are missing a ground, do whatever you need to replace it.
Not having one is gonna affect performance more than the way you make the connection, though you should try to do it properly.
morenolindo
Engine / Exhaust / Drivetrain
05-19-2009 10:02 AM
